Instrução
Publicar dados CAD como um serviço da feição hospedado no ArcGIS Online
Last Published: August 9, 2023
Resumo
Computer-aided design (CAD) data such as AutoCAD's DWG file and Bentley MicroStation's DGN file can be integrated with ArcGIS Pro maps as feature datasets. However, these file formats are not supported in ArcGIS Online, so the data must be converted to a file geodatabase feature in ArcGIS Pro before publishing it as a hosted feature service to ArcGIS Online.
Procedimento
  1. Convert the CAD dataset to a file geodatabase in ArcGIS Pro.
    1. On the ArcGIS Pro ribbon, click the Analysis tab > Tools.
    2. In the Geoprocessing pane, search for the CAD To Geodatabase tool, and click it.
    3. For Input CAD Datasets, select the CAD dataset to be converted.
    4. For Output Geodatabase, specify the file geodatabase for the output dataset.
    5. For Dataset, specify a name for the dataset created.
    6. For Reference scale, specify a reference scale.
    7. For Spatial Reference, select Current Map [Map] from the drop-down menu.
Image of the CAD to Geodatabase pane
  1. Click Run.
  1. Publish the file geodatabase to ArcGIS Online. Refer to ArcGIS Pro: Share a web feature layer using the default configuration for steps to do so.
ID do Artigo: 000024862
Obtenha suporte com IA
Comece a conversar agora
Informações Relacionadas
Descubra mais sobre este tema
Ir para as opções de download
