PROBLEMA
El botón Exportar está deshabilitado en ArcGIS Online
Last Published: July 19, 2023
Descripción
When attempting to export data from a hosted feature layer to a desired file type in ArcGIS Online, the Export button is disabled.
Image showing the Export button is disabled
Causa
This issue occurs when the Title and Tags fields are not specified.
Perform the following steps to resolve this issue:
  1. In ArcGIS Online, click Content > My Content.
  2. Browse to the desired hosted feature layer, click More Options , and click View item details.
  3. On the item details page, click either the Export To or Export Data button to export the hosted feature layer to the desired file type. Refer to ArcGIS Online: Export data from hosted feature layers for more information.
  4. In the Export to Shapefile (or any desired file type) window, ensure the Title and Tags fields are populated, and click Export.
Image showing the Export button is enabled
Id. de artículo: 000023666
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
