CÓMO
Note: The procedure below is for ArcGIS 9.3.1 or earlier versions. Starting from ArcGIS 10.0, expressions in the Calculator are created using only a VBScript or standard Python format. For the equivalent process in ArcGIS Desktop 10, refer to How To: Convert a file with coordinates in degrees, minutes, and seconds to a feature class or shapefile using ArcMap 10.x
Follow the steps below.
Code:
Dim sField
Dim sDMS As String, sS As String, sSuf As String, sPre as string
Dim sList
Dim i As Integer, j As Integer
Dim iDec As Integer, iNum As Integer
Dim dD As Double, dM As Double, dS As Double, dDD As Double
Dim bReplace As Boolean
'Change the source field name bellow
sField = [dms]
sDMS = sField
If Len(Trim(sDMS)) = 0 Then
dDD = 0
Else
iDec = 0
iNum = 0
For i = 1 To Len(sDMS)
sS = Mid(sDMS, i, 1)
If Not IsNumeric(sS) Then
If sS = "." Then
If Not iDec = 0 Then
bReplace = True
Else
bReplace = False
End If
iDec = iDec + 1
ElseIf sS = "-" Then
sPre = "-"
bReplace = True
Else
bReplace = True
End If
If bReplace Then
If iNum > 0 Then
Mid(sDMS, i, 1) = ","
Else
Mid(sDMS, i, 1) = " "
End If
End If
Else
iNum = iNum + 1
End If
Next i
sList = Split(sDMS, ",")
Dim iLen As Integer
If UBound(sList) = 0 Then
sDMS = sList(0)
iLen = Len(sDMS)
If iLen >= 4 Then
dS = CDbl(Mid(sDMS, iLen - 1, 2))
dM = CDbl(Mid(sDMS, iLen - 3, 2))
sDMS = Left(sDMS, (iLen - 4))
If (Len(sDMS) > 2) Then
dD = CDbl(Right(sDMS, 3))
ElseIf (Len(sDMS) = 0) Then
dD = 0#
Else
dD = CDbl(sDMS)
End If
Else
dDD = 0
End If
dDD = dD + dM / 60# + dS / 3600#
Else
j = 0
dD = 0#
dM = 0#
dS = 0#
For i = 0 To UBound(sList)
If IsNumeric(sList(i)) Then
If j = 0 Then
dD = CDbl(sList(i))
j = j + 1
ElseIf j = 1 Then
dM = CDbl(sList(i))
j = j + 1
ElseIf j = 2 Then
dS = CDbl(sList(i))
j = j + 1
End If
End If
Next i
End If
If dDD < -180# Or dDD > 180# Then
dDD = 0#
End If
If sPre = "-" Then
dDD = dDD * -1#
End If
End If
Note: Change the name of the field in the script to that of the original DMS fields. Change the source field name to: sField = [Long]
Note: Defining the projection allows the data to display as an Even layer in the correct location in ArcMap.
Id. de artículo: 000012735
Empieza a chatear ahora
