Instrução
Usar sobreposições de DXF no Site Scan Manager for ArcGIS
First Published: May 1, 2020
Last Published: September 1, 2023
Resumo
Instructions provided describe how to use drawing exchange format (DXF) overlays in Site Scan Manager for ArcGIS.
Overlays are one of the most widely used and important tools within Site Scan. DXF files are now supported in beta mode in Site Scan, making this tool even more versatile.
Procedimento
Upload DXF files in Site Scan for ArcGIS
DXF files can be uploaded like any other Site Scan Manager supported file.
This is the same workflow currently implemented for PDF overlays.
  1. Navigate to the upload button (+ plus sign) on the bottom-left corner of the map view and select Overlays.
Image showing Overlays dialog box
  1. In the Overlays dialog box, click Select Files to browse for DXF files on the computer.
Image showing Select Files UI
  1. After uploading the DXF file, enter the coordinate system (CRS) used by the DXF overlay and save it.
Image showing DXF overlay
Georeferencing DXF files
If the project uses a custom coordinate system, georeference the appropriate DXF.
  1. Right-click the DXF layer and select Georeference.
Image showing georeference
  1. Select a point on the map and match it with a point on the DXF. Choose the correct horizontal units from the top-right drop-down; Meters, Standard Foot, or U.S. Survey Foot. Click Next.
Image showing point to match
  1. Repeat the process for a second point, and click Finish. Once complete, the system redirects to the files section of the flight. Toggle on any of the uploaded DXF files. To re-position the DXF, click the location icon next to DXF Layers, as shown in the image below.
Image showing DXF file toggles
DXF Layers
Site Scan Manager imports all of the layers, with the same colors and names, of the original DXF file.
  • Visualize them by clicking on the drop-down arrow next to DXF Layers.
  • Turn individual layers on or off to better visualize different sections by sliding the toggle next to each of the layers, as shown in the image below.
Image showing toggle for layers
ID do Artigo: 000023064
Obtenha suporte com IA
Comece a conversar agora
Descubra mais sobre este tema
Ir para as opções de download
