Instrução
Exportar rasters para o formato GeoTIFF do ArcMap
Last Published: August 20, 2024
Resumo
The steps provided describe how to export a raster to GeoTIFF format in ArcMap.
Procedimento
  1. Add the raster to a blank mxd.
  2. Go to File > Export  Map.
  3. In the Export Map dialog, under Save as type, select TIFF.
  4. In the Options section, General tab, check Write World File, highlighted in the image below.
Export Map options, General tab
  1. On the Format tab, check Write GeoTIFF Tags and click Save, as shown in the following image.
Export map options, Format tab
ID do Artigo: 000026217
Obtenha suporte com IA
Comece a conversar agora
Informações Relacionadas
Descubra mais sobre este tema
Ir para as opções de download
