OBSOLESCENCIA
ArcGIS Enterprise 10.9.x, part of the ArcGIS 2021 releases, is the last release of ArcGIS Enterprise to support services published from ArcMap. For ArcGIS Data Reviewer for ArcGIS Enterprise customers, this change impacts capabilities delivered by the extension’s ArcMap runtime-based server object extension (SOE) and associated geoprocessing service. Beginning with the ArcGIS 2022 releases, these capabilities will no longer run after an upgrade of an existing deployment or available for use in new deployments.
To prepare for this change, Esri recommends that Data Reviewer customers consider migrating their automated review workflows to Data Reviewer’s capabilities available in ArcGIS Pro and attribute rules.
Several resources exist to help you make the switch to attribute rule-based workflows:
If you need features that are currently not available in ArcGIS Data Reviewer, please see the product roadmap or suggest an enhancement in the Esri Community.
Id. de artículo: 000026598
Empieza a chatear ahora
