CÓMO
Crear una plantilla de entidad poligonal con una geometría predefinida en ArcGIS Pro
First Published: October 29, 2020
Last Published: July 18, 2023
Resumen
When editing a feature class in ArcGIS Pro, a feature can be copied and pasted to other locations within the same layer. For example, when designing a new land subdivision, a few models of prefabricated houses are placed repeatedly on many different parcels by copying the feature and pasting it on other parcels. However, when pasting a feature, the feature is pasted at the same location from which it was copied. Users must go to the location of the copied feature, and use the repositioning tools to move the pasted feature to the desired location.
This article describes how to create a polygon feature template with a predefined geometry using a preset template to enable creating features with the same geometry repetitively in different locations without using the copy and paste functions.
Procedimiento
  1. In ArcGIS Pro, add the feature class to the map.
  2. Select the desired feature on the map, and create a preset template. Refer to ArcGIS Pro: Create a preset template for steps to do this.
  3. On the Edit tab, click Create The image of the Create button. to open the Create Features pane.
  4. Under the Templates tab, select the created preset template, and click on the map to place the feature at the desired locations.
The image of features created from the preset template.
  1. Optionally, modify the created features to move or rotate them as desired. Refer to ArcGIS Pro: Modify features for more information.
    1. On the Edit tab, click Modify to open the Modify Features pane.
    2. Select the modification method to modify the features as required.
Id. de artículo: 000024495
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
