PROBLEMA
No se puede iniciar sesión en ArcGIS Pro con una suscripción de uso personal
Last Published: August 5, 2025
Descripción
Starting July 22, 2021, changes were made to ArcGIS Personal Use subscriptions that require users to update their ArcGIS Online details.
Causa
To continue using ArcGIS Pro as part of an ArcGIS Pro Personal Use subscription, follow the below steps:
  1. Log in to ArcGIS Online
    • Use the same credentials used to log in to ArcGIS Pro
  2. Once logged in, follow the prompts to Update user type, as shown in the following image:
  1. Once updated, log in to ArcGIS Pro
If the issue persists, follow the steps below:
  1. Log into ArcGIS Online
  2. Select Organisation.
  3. Select Licenses.
  4. Select Manage next to any expired licenses and remove by toggling the switch to off, and close the pop-up window.
  5. Select Members in the top tab.
  6. In the same row as your username click the options ellipsis (More options), and click Manage User Type.
  7. Select the box under User Type.
  8. Select GIS Professional Advanced.
  9. Select Save.
You should now be able to use ArcGIS Pro.
Id. de artículo: 000026122
Obtenga soporte con IA
Empieza a chatear ahora
Información relacionada
Descubrir más sobre este tema
Ir a opciones de descarga
