HOW TO
If your support case is attached to an existing bug or has been diagnosed as a new bug with Esri software and it is adversely affecting your business, you can escalate the bug through for additional consideration in upcoming releases.
A bug can only be escalated if the following conditions are met:
Note: Enhancement requests cannot be escalated. To add your use case to an existing enhancement, you can create a technical support case or use the Ideas site to either create a new idea or support and existing idea.
To escalate a bug, follow the steps below.
Note: You must be an authorized caller and member of the organization in My Esri. This account must be linked to your Customer Number to view cases and bugs.
Note: Bugs leading to critical production issues should be reported to your Account Management team. If you are a member of Esri Premium Support or an International Distributor please contact your Technical Account Manager.
Artikel-ID: 000024129
Esri Support App herunterladen
You can also download the app to access the chatbot anytime! Download it now.
