ERROR
Verbindung zur Datenbank fehlgeschlagen. Allgemeiner Funktionsfehler Unerwarteter Fehler vom externen Datenbanktreiber
Fehlermeldung
Adding an .xls file to ArcMap returns the following error.
Error:
Failed to connect to database.
General function failure
Unexpected error from external database driver (1).
User-added image
Ursache
The error is returned due to having installed one of the following Microsoft updates:
Per Microsoft, "Installing this update may cause applications based on the Microsoft JET Database Engine (Microsoft Access 2007 and older or non-Microsoft applications) to fail when creating or opening Microsoft Excel .xls files. The error message is 'Unexpected error from external database driver (1). (Microsoft JET Database Engine)'".
Lösung oder Problemumgehung
Microsoft has provided an update to address this issue. Click the link below and install the appropriate update patch for the version and build of the operating system.
Artikel-ID: 000016969
Zugehörige Informationen
Zu Download-Optionen wechseln
