HOW TO
Anzeigen der einzelnen Features auf einer separaten Kartenserienseite in ArcGIS Pro
Last Published: August 20, 2024
Zusammenfassung
The steps provided describe how to show each feature on a separate map series page in ArcGIS Pro.
Vorgehensweise
To show each feature on a separate map series page, there must be a field in the table with a unique value for each feature, such as the OBJECT ID field.
  1. To use this field with your data, create a new numeric field, then use the Calculate Field tool to calculate its values. In the image below, there is a new field called Field with the OBJECT ID values calculated to it:
  1. In the Map Series Layout Properties, set the Name Field to the <new Field>.
  1. In the Layer Properties, select Page Query.
  2. Set the Filter to the <new Field> and choose the Match option, and click OK, as shown in the next image.
Now each feature is shown when the value of the <new Field> matches the page name, and the rest of the features are hidden.
Artikel-ID: 000026513
Zu Download-Optionen wechseln
