HOW TO
Custom expressions written in the Arcade expression language can be used to configure pop-ups in ArcGIS Online. Expressions can be used to modify the field values displayed in a layer's existing field.
This article provides the steps to exclude the time values displayed in a date field pop-up in ArcGIS Online Map Viewer. In this example, the field values in the UPDATED field is referenced as seen in the image below.
Text($feature.<field name>, 'MMMM D, Y')
The image below shows the DATE OF UPDATE field with the excluded time values after using the Arcade expression.
Artikel-ID: 000027471
