HOW TO
In ArcGIS Pro, features in a layer can be symbolized as a single symbol or unique values, or through the graduated colors method. In some instances, the features of a layer must be symbolized based on Hex or RGB color codes from the layer's attribute field so they can be differentiated. This article describes the steps to add Hex or RGB color codes from the attribute field as a feature symbology in ArcGIS Pro.
The image below shows an example of the Hex color codes.
The image below shows an example of the RGB color codes.
The image below shows the Hex color codes applied to the features of the layer.
Artikel-ID: 000024233
