HOW TO
In ArcGIS Pro, issues related to application failure and crashing can occur if the registry entry is corrupted. Performing a soft reset resolves the issue by closing applications and clearing data in the RAM, in contrast to a hard reset, whereby user data are removed and the device is restored to its factory settings. This article describes the workflow to perform a soft reset in ArcGIS Pro.
Note: If there are concurrent licenses on the machine, return any borrowed licenses before performing the workarounds below. For more information on borrowed licenses, refer to ArcGIS Pro: Start ArcGIS Pro with a Concurrent Use license.
Note: The AppData folder is hidden. To display hidden folders, refer to Microsoft Windows Support: Show hidden files.
C:\Users\YourUsername\AppData\Roaming\ESRI
C:\Users\YourUsername\AppData\Local\ESRI
Note: This information applies to ArcGIS Pro 2.9 and prior. At ArcGIS Pro 3.0, this folder is ArcGISPro_StrongName...
Article ID: 000027631
Get help from ArcGIS experts
Start chatting now
