HOW TO
Convert a TIN model from CAD data to a DEM in ArcGIS Pro
First Published: February 8, 2024
Last Published: February 8, 2024
Summary
Triangulated irregular networks (TINs) are surface models used to represent complex terrains or irregular surfaces in 3D modeling. TIN models are compatible with CAD file formats and can be added to a map in ArcGIS Pro using the CAD To Geodatabase tool. This method creates a feature dataset from a geodatabase, which allows the conversion of a TIN model to a digital elevation model (DEM) for visualization and spatial analysis.
This article provides the workflow to convert a TIN model from CAD data to a DEM in ArcGIS Pro. The image below shows the TIN model as CAD data for conversion to a DEM.
The TIN model from CAD data
Procedure
  1. Open the project in ArcGIS Pro.
  2. Convert the CAD data to a geodatabase feature dataset. Refer to How To: Convert CAD data to GIS data in ArcGIS Pro for instructions.
Image of the CAD To Geodatabase pane
  1. Add the output feature dataset in Step 2 to the map. Refer to ArcGIS Pro: Browse to data to add to a map or scene for instructions.
  2. Convert the multipatch feature class to a raster dataset using the Multipatch to Raster tool.
    1. On the Analysis tab, in the Geoprocessing group, click Tools.
    2. In the Geoprocessing pane, search for and click Multipatch to Raster (Conversion Tools).
    3. In the Multipatch to Raster pane, for Input multipatch features, select the multipatch feature layer from the drop-down list. In this example, the multipatch feature layer named MultiPatch_1 is selected.
    4. For Output raster, specify a location and name for the output raster dataset.
    5. For Cell assignment method, select the preferred method to use when more than one z-value is detected at the cell center. Refer to ArcGIS Pro: Parameters for more information. In this example, Maximum height is selected.
    6. Click Run.
The Multipatch to Raster pane
Create a layout to share the DEM raster layer as a printed map, poster, or PDF file. Refer to ArcGIS Pro: Make a layout for instructions.
The image below shows the DEM converted from the TIN model in ArcGIS Pro.
Image of the DEM raster
Article ID: 000031817
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
