HOW TO
Georeference multiple CAD data in ArcGIS Pro
Last Published: July 7, 2021
Summary
Georeferencing CAD data is the process of spatially adjusting a CAD drawing by linking points to known geographic coordinates. In some instances, multiple CAD data must be georeferenced by applying the same control points in ArcGIS Pro. This article provides the workflow to georeference multiple CAD data simultaneously using the same transformation in ArcGIS Pro.
Procedure
All CAD data must be stored in the same folder.
  1. In an ArcGIS Pro new project, set the projection of the map to be the same as the CAD data to georeference.
    1. In the Contents pane, right-click the map, and click Properties.
    2. In the Map Properties window, click Coordinate Systems, select a coordinate system, and click OK.
The map's coordinate system set to locate and display data correctly on the earth's surface.
  1. Add one of the CAD data (.dwg) to the map, and define the projection of the data.
    1. On the Map tab, in the Layer group, click Add Data The Add Data button..
    2. Navigate to and select the required CAD data, and click OK.
    3. In the Contents pane, click a layer of the CAD data.
    4. On the CAD Layer tab, in the Alignment group, click Define Projection Use the Define Projection tool to define the coordinate system of the CAD data..
The CAD Layer tab is not visible when a CAD group layer is selected. To display the tab, select a child feature layer in the CAD group layer.
  1. In the Define Projection window, for Coordinate System, select Current Map, and click Run.
The Define Projection window to select the  same projection.
  1. Georeference the CAD data. Click Save to apply the transformation and save the georeferencing control points to an auxiliary world (.wld) file in the CAD workspace. Refer to Georeference CAD data for more information.
  2. Navigate to the folder containing all the CAD data, and rename the projection (.prj) file to esri_cad.prj.
  3. Copy and paste the auxiliary world (.wld) file created in Step 3 within the same folder, and rename it to the name of other CAD data. Repeat this step depending on the numberĀ of CAD data (.dwg) that exist in the folder. In this example, there are three different .wld files with the same name as the three .dwg files (PARCEL_CAD, ROAD_CAD, and STREAM_CAD).
The list of CAD data (.dwg) and it's respective world (.wld) files.
  1. In ArcGIS Pro, add all the CAD data simultaneously. The CAD data are georeferenced and located at their respective locations.
The image below shows multiple georeferenced CAD data in ArcGIS Pro using similar control points and transformation.
The CAD data added to the map georeferenced using a similar transformation
Article ID: 000025645
Software:
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
