常见问题
常见问题解答:重置 ArcGIS Server 要素服务的必填字段
Last Published: September 14, 2023
答案
As an administrator, it may be necessary to ensure values are entered by field users in a specific field. Within the geodatabase information model, you can define a field as non-nullable and a value must be supplied for that attribute before it can be submitted. In Collector for ArcGIS, this may not be enforced when creating a new feature. See the Collector for ArcGIS blog: Require the information you need from the field
Esri has provided a workaround for Hosted Feature services on Github, however this is not applicable for ArcGIS Server services.  For ArcGIS Server services, it is necessary to add a property to the Feature Service via the Server Admin directory at REST, as follows.
  1. Go into the server’s admin REST page – for example: 
https://myserver.esri.com:6443/arcgis/admin/login
  1. Log in as the admin.
  2. Go to the services page, for example:
 https://relic.esri.com:6443/arcgis/admin/services
  1. Click the service that they are using, for example:
 https://relic.esri.com:6443/arcgis/admin/services/emptygeom.MapServer
  1. Scroll to the bottom of the page and click Edit.
  2. Go to the feature service section and at the bottom add the following:
"setDefaultsToNullForNotNullFieldsInTemplates":"true"
  1. Click Save.
  2. Reset the service.
文章 ID: 000022706
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
