操作方法
操作方法:使用字段计算器将十进制度值转换为度分秒值
Last Published: October 20, 2023
摘要
Python scripts are specific to the version of Python that was shipped with the version of ArcMap in use. Therefore, this script may not work with your version of ArcMap. However, this script may serve as a template for modification, if desired.
Refer to FAQ: What version of Python is used in ArcGIS? for more information.
To perform coordinate conversion, Esri recommends using the Convert Coordinate Notation tool in ArcToolbox > Projections and Transformations toolset.
Instructions provided describe how to use the Field Calculator to convert Decimal Degrees stored in a numeric field to Degrees Minutes Seconds stored in a text field. The output by default is in the following format:
DD°MM'SS.SS"N
过程
Follow the steps below:
  1. Add the table to ArcMap.
  2. Right-click the table in the Table of Contents and select Open.
  3. Verify that Edit mode is not enabled. Click the Options button and select Add Field.
  4. Type DMSLat in the Name field and select Text from the Type drop-down list. If DMSLat is already used as a field name, select a name that is not being used.
  5. Change the length to 20.
  6. Right-click on the DMSLat field and select Calculate Values.
  7. Click Yes if presented with a message box.
  8. Change the Parser from VB Script to Python.
  9. Check the box to Show Codeblock.
  10. Paste the following code into the Pre-Logic Script Code box:
def decimalDegrees2DMS(value,type):
        Converts a Decimal Degree Value into
        Degrees Minute Seconds Notation.
        Pass value as double
        type = {Latitude or Longitude} as string
        returns a string as D:M:S:Direction
        created by: anothergisblog.blogspot.com
    degrees = int(value)
    submin = abs( (value - int(value) ) * 60)
    minutes = int(submin)
    subseconds = abs((submin-int(submin)) * 60)
    direction = ""
    if type == "Longitude":
        if degrees < 0:
            direction = "W"
        elif degrees > 0:
            direction = "E"
        else:
            direction = ""
    elif type == "Latitude":
        if degrees < 0:
            direction = "S"
        elif degrees > 0:
            direction = "N"
        else:
            direction = ""
    notation = str(degrees) + u"\u00b0" + str(minutes) + "\'" +\
               str(subseconds)[0:5] + "\"" + direction
    return notation
  1. Paste one of the following code into the DMSLat = expression box at the bottom of the dialog box depending on the desired latitude or longitude data.
decimalDegrees2DMS( !Latitude_Field_Name! ,"Latitude")
decimalDegrees2DMS( !<Longitude_Field_Name! ,"Longitude")
  1. Click OK to run the Field Calculator.
  2. Repeat steps 3 through 12 for the longitude values, but change the first parameter in the DMSLong expression box to the field in the table that contains the longitude decimal degree values and replace the word Latitude in the second parameter with the word Longitude.
文章 ID: 000008758
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
