错误
When attempting to publish a service referencing an enterprise database or geodatabase in ArcGIS Server 10.5.0, the following error is returned:
Error: Error executing tool. PublishServiceDefinition Job ID: jXXXXXXXXXXXXXX : ERROR 001487: Failed to update the published service with the server-side data location. Please see the server's log for more details.
Note: In certain cases, existing services that use these connections may work properly, and data stores may validate successfully.
The 'dsconnections.lst' file is not present in the following directories:
C:\arcgisserver\config-store\data C:\Program Files\ArcGIS\Server\DatabaseSupport
This file is not generated when the 'Validate All' command is run via ArcGIS Server Manager. This issue is caused by a defective patch, the 'ArcGIS Server Geoprocessing Service Startup Patch' for 10.5.0.
文章 ID: 000019106
获取来自 ArcGIS 专家的帮助
立即开始聊天
