操作方法
操作方法:将等值线转换为 CAD 格式
Last Published: October 20, 2023
摘要
Instructions provided describe how to convert contour lines to CAD format, while preserving elevation values.
过程
Follow the steps below:
  1. Convert the lines to a 3D layer. Add the 3D Analyst toolbar to ArcMap. Open the 3D Analyst drop-down menu > Convert > Features to 3D. Use the contour field as the source of heights.
  2. Convert the 3D layer to points using the ArcToolbox > Data Management Tools > Features > Feature to Point tool.
  3. Use the Set CAD Alias tool to assign TxtValue to the field that contains the contour values. This is found in ArcToolbox > Conversion Tools > To CAD > Set CAD Alias. Click the box next to contour and select TxtValue.
This is a deprecated tool at ArcGIS version 10 and later. To learn more about how this tool works, See the article Set CAD Alias (Conversion). This functionality can be accomplished using Add Field and making simple field calculations.
  1. Use the Export to CAD tool to export both the point and 3D line shapefiles to a .dwg file.
文章 ID: 000008655
获得人工智能支持
使用 Esri Support AI Chatbot 快速解决您的问题。
立即开始聊天
相关信息
发现关于本主题的更多内容
获取来自 ArcGIS 专家的帮助
联系技术支持部门
立即开始聊天
转至下载选项
