HOW TO
In ArcGIS Pro, the spatial and location information of point features can be added to the attribute fields using geoprocessing tools such as the Add XY Coordinates tool and the Calculate Geometry Attributes tool. The Add XY Coordinates tool can be used to calculate the XY coordinates of point features, however, this tool does not provide the option to select the coordinate format of the output.
This article provides the workflow to calculate the XY coordinates of point features using the Calculate Geometry Attributes tool which provides enhanced functionality and performance.
Note: To populate the x- and y-coordinates in the same field, select Point x- and y-coordinate notation from the Property drop-down list.
The x- and y-coordinates of the point features are populated in the new fields.
Article ID: 000026530
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
