HOW TO
Concatenate text and numeric fields in ArcGIS Pro
Last Published: August 9, 2023
Summary
In ArcGIS Pro, the Field Calculator tool can be used to concatenate two or more text fields to display the combined field attributes in a new field. Text and numeric fields must, in some cases, be concatenated into one field to combine the attribute values.
The steps provided in this article describe how to concatenate text and numeric fields into a new field using casting in Field Calculator, which converts all the fields to text fields.
In this example, the Name (text), Gender (text), and Student_ID (numeric) fields are concatenated into the new Top_Students_ID text field.
Procedure
This workflow retains the original field data type and treats it as a text field in the Python expression to enable concatenation.
  1. Add a new text field in the attribute table to store the concatenated attributes. Refer to ArcGIS Pro: Fields view for steps to create a new text field.
The field to store the concatenated attributes must be a text field. Refer to ArcGIS Blog: Concatenating field values using Calculate Field for more information. Using an existing field is possible, but the output of this process overwrites existing data in the field.
  1. In the attribute table, right-click the new field name, and select Calculate Field. In this example, it is Top_Students_ID.
Image showing the Calculate Field option for the target field in the attribute table.
  1. In the Calculate Field geoprocessing pane, type the following expression, and replace Field Name with the name of each field to concatenate.
str(!Field Name!) + " " + str(!Field Name!) + " " + str(!Field Name!)
The ‘str’ constructor function specifies the field data type to be string. Refer to Python Casting for more information. Remove the double quotation marks (" ") to eliminate the space if required. Do not remove the exclamation marks surrounding the field names.
In this example, the field names are Name, Gender, and Student_ID.
Image showing the field names for truncating.
  1. Click Run. The fields are concatenated and displayed in the new field.
Image showing the fields are concatenated and displayed in the new field.
Article ID: 000023857
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
