PROBLEM
In some instances, when attempting to save an ArcMap project, the following message is returned:
Error: ArcMap is unable to save the map document due to the file being held open by the operating system. To resolve, please retry your save operation or use Save As to save to a different file name.
This issue may occur due to the following reasons:
Depending on the cause, use one of the workarounds below to address the issue.
Change the machine's sleep settings
Note: The machine must be restarted before and after completing the workflow for the changes to take effect.
Note: For Windows 10, refer to Microsoft: How to adjust power and sleep settings for more information on changing the sleep settings.
Note: Esri recommends selecting 'Never' for the Put the computer to sleep: settings.
Offline storage capacity is full
Note: If the problem persists, work with the organization's IT department as this involves the operating system.
Article ID: 000021614
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
