PROBLEM
When attempting to use an ArcGIS product with a Concurrent Use license, users cannot connect to ArcGIS License Manager, preventing the use of ArcGIS products such as ArcMap, ArcGIS Pro, and ArcCatalog. Launching these products may result in them freezing or not loading.
There are various reasons why a user may not be able to connect to ArcGIS License Manager, some of which are listed below:
There are six solutions outlined below to troubleshoot and resolve issues connecting to ArcGIS License Manager. Follow the solutions in the order they are presented, and attempt to connect to ArcGIS License Manager after each solution.
Verify the version compatibility of ArcGIS License Manager and the client software
ArcGIS License Manager is compatible with client software of the same version or older. Refer to License Manager Guide: Supported software products for more information on what client versions are compatible with the relevant ArcGIS License Manager version.
Verify ArcGIS License Manager is running
A client machine is unable to connect to ArcGIS License Manager if ArcGIS License Manager is not running.
Restart ArcGIS License Manager and FlexNET Licensing services
ArcGIS License Manager may stop running due to specific settings in Windows Services. Modifying these settings ensures ArcGIS License Manager runs automatically.
Connect to ArcGIS License Manager via an IP address
Connecting to ArcGIS License Manager via an IP address ensures that ArcGIS Administrator is accessing the correct ArcGIS License Manager.
Connect to ArcGIS License Manager via a port
ArcGIS License Manager can run on ports 27000 to 27009. Other programs may interfere with the connection if the same port is used, preventing ArcGIS Administrator from connecting to ArcGIS License Manager. To prevent this, connect to ArcGIS License Manager via a specific port.
Modify the service.txt file
By default, the service.txt file does not denote a specific port for ArcGIS License Manager to use. Editing this file locks ArcGIS License Manager to a specific unused port.
C:\Program Files\ArcGIS\License10.x\bin
SERVER this_host ANY VENDOR ARCGIS FEATURE ACT ARCGIS 1 permanent 1 7ED49106D630
SERVER this_host ANY 27000 VENDOR ARCGIS port=27004 FEATURE ACT ARCGIS 1 permanent 1 7ED49106D630
Note: Any value between 27000 and 27009 can be used for VENDOR ARCGIS PORT.
Configure the firewall
Firewall configurations may prevent ArcGIS License Manager from receiving and making connections. The firewall must be configured to allow ArcGIS License Manager to work through it.
Article ID: 000019755
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
