PROBLEM
Point features become hollow vertical columns when extruded in ArcGIS Pro
First Published: July 3, 2019
In ArcGIS Pro, when extruding point features based on a height value to create 3D shapes in a scene, the point features become hollow, vertical columns as seen in the image below.
Extruded point features with hollow vertical columns
Cause
This is expected behaviour in ArcGIS Pro, and is described in ArcGIS Pro: Extrude points.
Solution or Workaround
To create non-hollow vertical columns, follow the instructions described below:
  1. In ArcGIS Pro, right-click the desired point layer and select Symbology.
  2. In the Symbology pane, click the point symbol, and change the symbology to 3D symbols. Select the desired 3D symbol.
point symbol
  1. Click the Appearance tab. In the Extrusion group, click the Type drop-down arrow. Select None to remove the extrusion function.
Appearance tab
  1. Click the back button in the Symbology pane and select the Vary symbology by attribute icon.
Back button
  1. Click the Size drop-down arrow and uncheck the Maintain aspect ratio check box.
  1. Set the desired height field for the Height property.
Height property
  1. Check the Enable size range text box and change the Minimum and Maximum size to the desired range.
Maximum and Minimum Range
The image below shows the 3D point features with non-hollow vertical columns.
3D point symbols
Article ID: 000021382
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
