HOW TO
Transfer a custom color scheme in ArcGIS Pro to a different machine
First Published: August 31, 2023
Last Published: October 2, 2023
Summary
Custom color schemes can be created in ArcGIS Pro, and these can be saved as styles, such as a custom or Favorites style, and used in any project. Refer to ArcGIS Pro: Create a custom color scheme for more information.
Custom styles can be transferred to a different machine by sharing the custom style as a web style to ArcGIS Online or ArcGIS Enterprise and accessed in ArcGIS Pro on the other machine. However, only valid symbols are included in web styles, and color schemes are not included. Refer to ArcGIS Pro: Share a web style for more information.
This article provides the workflow to transfer a custom color scheme in ArcGIS Pro to a different machine, which is useful when bringing a custom color scheme from an old machine to a new one.
The image below shows a custom color scheme in an ArcGIS Pro project.
A custom color scheme in an ArcGIS Pro project
Procedure
  1. Open the ArcGIS Pro project.
  2. Save the customized color scheme as a Favorites style. Refer to ArcGIS Pro: Save colors in a style for more information.
  3. In the Catalog pane, expand Styles, right-click Favorites and select Manage Style to open the catalog view.
  4. On the top ribbon, click View > Details Panel.
  5. In the catalog view, select the Favorites folder. In the details panel, under Path, take note of the 'Favorites.stylx' file path. In this example, the file path is:
C:\Users\<username>\AppData\Roaming\ESRI\ArcGISPro\Favorites.stylx
The file path of the Favorites folder in the details panel
The Application Data (or AppData) folder is hidden by default. Refer to FAQ: What are the user.config files for in ArcMap and ArcGIS Pro? for more information.
  1. Unhide, navigate to, and select the Favorites.stylx file on the machine.
Unhiding hidden files and folders in File Explorer
The Favorites style file in File Explorer
  1. Upload the Favorites.stylx file to a cloud drive.
  2. On the different machine, navigate to the Favorites.stylx file on the cloud drive and download it to the machine’s file system.
  3. Launch ArcGIS Pro and add the style to a project. Refer to ArcGIS Pro: Add styles to a project for more information.
The image below shows the custom color scheme ready to be used in ArcGIS Pro on the different machine.
The custom color scheme in ArcGIS Pro on a different machine
To delete a color scheme from a style, right-click the item in the style folder and click Delete.
Article ID: 000031207
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
