HOW TO
Remove the ArcGIS Data Store tile cache data store from an ArcGIS Enterprise deployment
First Published: December 23, 2024
Last Published: July 31, 2026
Summary
After migrating all hosted scene layer caches to the object store, the tile cache data store can be disabled. This process unregisters the tile cache data store from the hosting server and deletes most tile cache data store files from the machine to save resources. For more information, refer to ArcGIS Server: Migrate hosted scene layer caches using the MigrateSceneService utility. Depending on how and where the tile cache data store was created, it is possible to remove the tile cache data store from the ArcGIS Enterprise deployment. The following table summarizes the tile cache data store removal options of various ArcGIS Enterprise deployment scenarios.
The disabledatastore utility is specific to tile cache data stores and was introduced at ArcGIS Enterprise 11.4.
For customers who are upgrading from 11.3 or earlier versions, when migrating tile cache data stores to the objectstore, the solution is to unregister the tile cache datastore before uninstalling it. See: What's new in ArcGIS Data Store 11.4.
Procedure
How to remove the ArcGIS Data Store tile cache data store (if applicable)
You installed each ArcGIS Enterprise component individually on Windows machines, but the tile cache data store is installed on the same machine as another type of ArcGIS Data Store. After disabling the tile cache data store, uninstall the tile cache data store from the machine. Refer to ArcGIS Enterprise: Uninstall specific types of data stores for instructions.
You installed ArcGIS Enterprise components on Linux or Windows machines, and you installed the tile cache data store on machines that are separate from all other Enterprise components including other ArcGIS Data Store types.
After disabling the tile cache data store, uninstall ArcGIS Data Store from the tile cache data store machines. Refer to ArcGIS Enterprise: Uninstall ArcGIS Data Store for instructions.
Created using ArcGIS Enterprise Cloud Builder for Amazon Web Services (AWS)The tile cache data store can be disabled, but the installation cannot be removed from the deployment.
You installed ArcGIS Enterprise components on Linux machines, and you installed the tile cache data store on the same machine as other ArcGIS Data Store configuration types, such as the relational data store. The tile cache data store can be disabled, but the installation cannot be removed from the deployment.
Created using the AWS CloudFormation templates provided by Esri that create the tile cache data store on machines separate from all other ArcGIS components, including other ArcGIS Data Store types. Remove the tile cache data store on AWS EC2 instances from the deployment. Refer to How To: Remove the tile cache data store from an ArcGIS Enterprise deployment on Amazon Web Services for instructions.
Created using ArcGIS Enterprise Cloud Builder for Microsoft Azure.Remove the tile cache data store virtual machines from the deployment. Refer to How To: Remove the tile cache data store from an ArcGIS Enterprise deployment on Azure for instructions.
Created using ArcGIS Enterprise Builder.The tile cache data store can be disabled, but the installation cannot be removed from the deployment.
Article ID: 000034373
Software:
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
