HOW TO
Change the highway shield marker colors in ArcGIS Pro
First Published: July 26, 2019
Last Published: February 9, 2024
Summary
A highway shield is a sign used to indicate the route number of a highway. It varies in shape and color with a route number enclosed. In some cases, the colors of the highway shield are changed to accommodate current law enforcements. However, in ArcGIS Pro, there is no option to change the colors.
Procedure
As a workaround, follow the instructions described below.
  1. In ArcGIS Pro, select the desired highway shield as a point symbol.
Ensure the labels of the layer are enabled. Refer to ArcGIS Pro: Turn on labels for more information.
  1. In the Contents pane, right-click the desired layer and select Labeling Properties....
The 'Labelling Properties...' option in the Contents pane.
  1. In the Label Class - <layer name> pane, click the ;Symbol tab. Expand the Callout node and select Point symbol.
The Point symbol callout in the Label Class pane.
  1. Click Apply.
  2. Click the Labelling tab, select the desired shield symbol in the Text Symbol group. In this example, Shield 1 is selected.
Shield symbol
  1. In the Label Class - <layer name> pane, under the Callout node, for Point symbol, select Format point symbol... from the drop-down list.
The Label Class pane.
Ensure the layers are unlocked. Refer to ArcGIS Pro: Color locking for more information.
  1. Modify the color of the shield symbol and click Apply.
    To save the new symbol style, click the Menu The Menu icon. button in the Label Class pane and click 'Save symbol to style...'. For more information, refer to ArcGIS Pro: Save symbols in styles.
    The image below show the modified highway shield marker symbol colors in ArcGIS Pro.
    Modified highway shield marker symbol color in ArcGIS Pro.
    Article ID: 000021556
    Software:
    • ArcGIS Pro
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
