ERROR
java.lang.UnsatisfiedLinkError: no ntvinv in java.library.path
First Published: May 5, 2016
Last Published: December 18, 2024
Error Message
When compiling or executing a Java application that uses the ArcObjects Java API, the following error is returned:
Error:
Cause
The PATH variable does not include a directory which contains the native libraries required for ArcObjects Java classes to function.
Solution or Workaround
Add the directory containing the native libraries required by ArcObjects Java to the PATH variable.
  • On both Windows and Unix platforms, add either one of the following directories to the PATH variable:
    A. $ARCENGINEHOME\java\jre\bin
    B. $ARCENGINEHOME\bin
    $ARCENGINEHOME may have to be replaced with the location of the ArcGIS SDK installation.
  • Unix also provides the option of running the ArcEngine helper scripts in $ARCENGINEHOME: init_engine.csh or init_engine.sh.
  • Refer to the environment settings documentations in the Related Information section for additional information.
Article ID: 000007942
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
