ERROR
When attempting to add, remove, or change the installation of ArcGIS products, the following error message may return:
Error: Error 1606: Could not access the network location
Note: There are many situations under which Error 1606 may be encountered. If a this error is returned, the best resource to find out why and to help remedy the issue is to provide a Windows Installer log file and analyze it.
This issue may occur if there is an incorrect setting in one of the registry keys related to Shell Folders.
Warning: The instructions below include making changes to essential parts of your operating system. Esri recommends backing up your operating system and files, including the registry, before proceeding. Consult with a qualified computer systems professional, if necessary. Esri cannot guarantee results from incorrect modifications while following these instructions; therefore, use caution and proceed at your own risk.
Verify that the values that correspond to user Shell Folders are set correctly and have a valid value.
Value Name Value Data ============================== AppData %USERPROFILE%\Application Data Cache %USERPROFILE%\Local Settings\Temporary Internet Files Cookies %USERPROFILE%\Cookies Desktop %USERPROFILE%\Desktop Favorites %USERPROFILE%\Favorites History %USERPROFILE%\Local Settings\History LocalAppData %USERPROFILE%\Local Settings\Application Data Local Settings %USERPROFILE%\Local Settings My Pictures %USERPROFILE%\My Documents\My Pictures NetHood %USERPROFILE%\NetHood Personal %USERPROFILE%\My Documents PrintHood %USERPROFILE%\PrintHood Programs %USERPROFILE%\Start Menu\Programs Recent %USERPROFILE%\Recent SendTo %USERPROFILE%\SendTo Start Menu %USERPROFILE%\Start Menu Startup %USERPROFILE%\Start Menu\programs\Startup Templates %USERPROFILE%\TemplatesWindows Vista, Windows 7, Windows Server 2008 and Windows 10
{374DE290-123F-
4565-9164-
39C4925E467B} %USERPROFILE%\Downloads
AppData %USERPROFILE%\AppData\Roaming
Cache %USERPROFILE%\AppData\Local\Microsoft\Windows\Temporary Internet Files
Cookies %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Cookies
History %USERPROFILE%\AppData\Local\Microsoft\Windows\History
LocalAppData %USERPROFILE%\AppData\Local
My Pictures %USERPROFILE%\Pictures
My Music %USERPROFILE%\Music
My Video %USERPROFILE%\Videos
NetHood %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Network Shortcuts
Personal %USERPROFILE%\Documents
PrintHood %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Printer Shortcuts
Programs %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs
Recent %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Recent
SendTo %USERPROFILE%\AppData\Roaming\Microsoft\Windows\SendTo
Start Menu %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu
Startup %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
Templates %USERPROFILE%\AppData\Roaming\Microsoft\Windows\Templates
Note: Repeat steps 5 and 6 for any of the values that were deleted.
Windows XP and Windows Server 2003
Value name Value data ============================= Common AppData %ALLUSERSPROFILE%\Application Data Common Desktop %ALLUSERSPROFILE%\Desktop Common Documents %ALLUSERSPROFILE%\Documents Common Favorites %ALLUSERSPROFILE%\Favorites Common Programs %ALLUSERSPROFILE%\Start Menu\Programs Common Start Menu %ALLUSERSPROFILE%\Start menu Common Startup %ALLUSERSPROFILE%\Start Menu\Programs\Startup Common templates %ALLUSERSPROFILE%\Templates
{3D644C9B-1FB8-
4f30-9B45-
F670235F79C0} %PUBLIC%\Downloads
Common AppData %ProgramData%
Common Desktop %PUBLIC%\Desktop
Common Documents %PUBLIC%\Documents
Common Programs %ProgramData%\Microsoft\Windows\Start Menu\Programs
Common Start Menu %ProgramData%\Microsoft\Windows\Start Menu
Common Startup %ProgramData%\Microsoft\Windows\Start Menu\Programs\Startup
Common templates %ProgramData%\Microsoft\Windows\Templates
CommonMusic %PUBLIC%\Music
CommonPictures %PUBLIC%\Pictures
CommonVideo %PUBLIC%\Videos
Note: Again repeat steps 10-11 for each of the values that were removed.
Note: Alternatively, use the Microsoft Fix-It utility to automatically clean up the issues and uninstall the program. Refer to Microsoft Support: Fix problems that block programs from being installed or removed for more information.
Article ID: 000007987
Get help from ArcGIS experts
Start chatting now
