PROBLEM
"Error 1606: Could not access the network location" encountered when attempting to add the installation of ArcGIS for AutoCAD 400
Last Published: January 27, 2021
When installing ArcGIS for AutoCAD version 400, the following error may be encountered:
Cause
ArcGIS for AutoCAD is installed into the %ProgramFiles%/Autodesk/ApplicationPlugins folder. If this folder is missing or not accessible by the current user, ArcGIS for AutoCAD cannot be installed.
Solution or Workaround
There are two workarounds:
  • Recommended: Reinstall AutoCAD to recreate the folder.
 Or,
  • Create a new folder titled “ApplicationPlugins” in the %ProgramFiles%/Autodesk folder (this may have unintended consequences when installing and uninstalling AutoCAD plugins)
Article ID:000025046
Software:
  • ArcGIS for AutoCAD 400
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
