Frequently asked question
ArcGIS Flight has a variety of flight modes depending on the type of area or structure that you intend to map or model. These can be large areas, individual structures, manual inspections, or a combination of all of them. The supported flight modes include:
Area Survey flight mode follows the traditional lawn mower flight path that is found across third-party flight apps. This flight pattern is effective at mapping large areas in a quick and efficient manner. The drone is typically flown with the camera pointed straight down at the surface at a 0-degree gimbal angle (nadir).
When to use Area Survey:
The image below shows a the flight path (green line) for an Area Survey with camera projections indicated by the green pyramids. The area being scanned is indicated by the blue rectangle.
Crosshatch Survey flight mode is best suited for sites that have vertical features that need to be captured. This flight mode uses a crosshatched flight path so it will take double the resources (time, batteries and images taken) to complete compared to a traditional Area Survey flight. This pattern must be flown with the camera set at an angle; a camera angle set between 35 and 40 degrees delivers the best results in most cases. Due to the crosshatched pattern and the oblique gimbal angle used when flying, this flight mode will capture the features of your site from multiple perspectives you with rich data for generating point clouds or meshes. Photos from a Crosshatch Survey can be merged with an Area Survey for higher quality processing.
When to use Crosshatch Survey
The image below shows a the flight path (green line) for a Crosshatch Survey with camera projections indicated by the green pyramids. The area being scanned is indicated by the blue square.
Perimeter Scan flight mode is ideal for creating high-resolution 3D models of tall individual structures like buildings, cell towers, and spires. The drone will orbit the structure at multiple altitudes. Photos from a Perimeter Scan can be merged with an Area Survey for higher quality processing.
When to use Perimeter Scan:
Considerations:
The image below shows a the flight path (green line) for a Perimeter Scan with camera projections indicated by the green pyramids. The structure being scanned is indicated by the blue cube.
Vertical flight mode is effective in capturing façades of vertical structures such as a building, dam, or mining site. This flight mode has additional settings that allow for angled façades, both those with a fixed or variable slope. You can merge a Vertical Scan with an Area Survey or a Crosshatch Survey to get richer 3D results.
When to use Vertical:
Considerations:
The image below shows a the flight path (green line) for a Vertical flight with camera projections indicated by the green pyramids. The façade being scanned is indicated by the blue rectangle.
Panorama flight mode is ideal for creating a 360-degree panorama photo to capture a complete view of a job site and the surrounding area. The panorama generated will include the area directly underneath the drone.
When to use Panorama:
Considerations:
The image below shows the coverage area (blue cone) of a Panorama flight. The drone will ascend to the user-defined flight height, and rotate (yaw) to capture imagery of the area within the cone.
Corridor Scan is suited for capturing long and narrow areas of interest. Corridor Scans can be conducted with the drone to flying directly over or next to and along side the corridor of interest.
When to use Corridor Scan:
Considerations:
The image below shows a the flight path (green line) for a Corridor Scan with camera projections indicated by the green pyramids. The corridor of interest is indicated by the narrow blue rectangle.
Inspection is ArcGIS Flight's manual flight mode. After takeoff, the drone will autonomously climb to the predetermined flight height where it is entirely reliant on the pilot for further movement. Inspection allows pilots to control their drone with more flexibility than a predetermined flight plan. You can manually take photos of areas of interest or you can record a video.
When to use Inspection:
Article ID: 000022893
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
