ERROR
Failed to create new feature(s). General Function Failure [database error has occurred.]
Last Published: February 18, 2022
Error Message
Attempts to create new features in a hosted feature layer in ArcGIS Pro fail, and return the following error message:
Error:
General function failure [Database error has occurred.]
Error message.
Cause
The relational data store in which the hosted feature layer is stored is set to read-only. In most cases, the relational data store is automatically set to read-only due to insufficient disk space.
Solution or Workaround
To resolve the error, change the relational data store setting from read-only to read-write mode using the following workflow.
  1. Open Windows Command Prompt as an administrator.
    1. Log in to the ArcGIS Data Store machine as an administrator.
    2. Right-click the Command Prompt app icon and select Run as administrator.
  2. Navigate to the ArcGIS Data Store tools directory using the following command line:
cd C:\Program Files\ArcGIS\DataStore\tools
  1. Ensure the relational data store is set to read-only. In the Command Prompt window, run the describedatastore utility.
C:\Program Files\ArcGIS\DataStore\tools>describedatastore
If the relational data store is in read-only mode, the prompt returns the following message:
Image showing the read-only mode setting.
  1. Change the relational data store setting from read-only to read-write. In the Command Prompt window, run the changedatastoremode utility. Refer to Portal for ArcGIS: changedatastoremode for more information.
C:\Program Files\ArcGIS\DataStore\tools>changedatastoremode readwrite --store relational --prompt no
In ArcGIS Data Store versions prior to version 10.8.1, the command line in Step 4 reads as follows:
When prompted with Do you wish to continue (Yes or No)?, type Yes, and press Enter.
  1. If the relational data store is automatically set to read-only due to low disk space, re-enable automatic backups. Run the updatebackupschedule utility. Insert the values for starttime and frequency in the command line. Refer to Portal for ArcGIS: updatebackupschedule for more information.
updatebackupschedule --starttime 23:00:00 --frequency 10
Update backup schedule.
Article ID: 000022570
Software:
  • ArcGIS Data Store
  • ArcGIS Pro
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
Esri Support AI Chatbot
