HOW TO
In ArcGIS Pro, features can be symbolized based on an attribute field in a dataset using unique values symbology. In some cases, it is necessary to set a different color to one or more features of the same symbology to highlight a unique value.
The workflow below describes steps to set a different color symbology to one of the features originally symbolized based on the Type field.
In the attribute table, there are three different Type fields: Fill, Synthetic, and Land , and they are symbolized by the colors Red, Yellow, and Green respectively. In this article, one of the three features of the Fill Type field is set to a different color based on the Name field (Duho).
Note: The second Field must be a unique value. If the second Field has repeats, all the features with the same Field value share the same color symbology.
Article ID: 000022064
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
