ERROR
When opening or creating a project or map document in ArcGIS Pro or ArcMap, the following error message is returned:
Error: LoadLibrary failed with error 87: The parameter is incorrect.
This issue occurs due to the machine's graphics card configuration.
Depending on the cause, either:
Get help from ArcGIS experts
Download the Esri Support App
You can also download the app to access the chatbot anytime! Download it now.
