How To: Stop GIS services using ArcGIS API for Python
Summary
ArcGIS Server services can be stopped from ArcGIS Server Manager, ArcCatalog, or the catalog window in ArcMap. In some cases, there may be several services which must be stopped, and stopping them manually is tedious. For federated ArcGIS Servers, the ArcGIS API for Python's stop() function may be used to automate the process.
Procedure
The following steps describe how to stop services in a GIS folder using the stop() function:
- Import the necessary libraries.
from arcgis.gis import GIS import arcgis.gis.admin
- Specify the GIS server details.
gis = GIS("<portal url>", "<portal admin username>", "<portal admin password>")
Note: To bypass the certificate verification, add the following parameter, 'verify_cert=False'.
- Retrieve available folders in the server, and specify it in a parameter.
gis_servers = gis.admin.servers.list()
Note: If the desired server folder array location is known in the list, the script can be modified to: servers = gis.admin.servers.list()[0] "[0]" can be modified to specify the exact location of the service in the array. In the example, the script grabs the first service in the list.
- Loop through the list and stop all services for all servers in a federated environment.
for server in gis_servers: for service in server.services.list(): service.stop()
Note: To stop specific services, the code can be modified as follows: for server in gis_servers: for service in server.services.list(): if service.properties.serviceName == "SampleWorldCities": service.stop() The code sample searches for the service name with SampleWorldCities and stops it.
The following shows the full code:
from arcgis.gis import GIS import arcgis.gis.admin gis = GIS("https://machine.domain.com/portal", "admin", "password", verify_cert=False) gis_servers = gis.admin.servers.list() #To stop all services for server in gis_servers: for service in server.services.list(): service.stop() #To stop specific service(s) for server in gis_servers: for service in server.services.list(): if service.properties.serviceName == "SampleWorldCities": service.stop()
Related Information
- ArcGIS Pro: Connect to a GIS server
- ArcGIS API for Python: Managing your GIS servers
- ArcGIS Server: Start and stop services
Last Published: 2/16/2021
Article ID: 000019994
Software: ArcGIS API for Python 1.8.4, 1.8.3, 1.8.2, 1.8.1, 1.8.0, 1.7.1, 1.7.0, 1.6.1, 1.6 Portal for ArcGIS 10.7.1, 10.7, 10.6.1, 10.6
