Frequently asked question
Is it possible to add arrow symbols in ArcGIS Online?
Yes, as of the December 2017 update to ArcGIS Online, the arrow symbols are available in ArcGIS Online. The arrow symbols are used to show the line directions in road networks, utility networks, or stream flow.
For single-arrow lines, the placement of arrow is based on the start and end points of each line feature.
Follow the steps provided below to symbolize the lines with arrows:
  1. In the ArcGIS Online Contents pane, select the desired layer, and click Change Style.
    An image of the Change Style option in the Contents pane.
  2. In the Change Style pane, navigate to Select a drawing style > OPTIONS.
    An image the Options button in the Change Style pane.
  3. Click Symbols to open the Change symbols pane.
    The Symbols option on the Change Style pane.
  4. Select the desired line color, width, and pattern.
  5. For Arrow, click the drop-down arrow, and select the desired arrow symbology.
    An image of selecting an arrow symbology.
  6. Click OK to close the Change symbols pane.
  7. In the Change Style pane, click OK and DONE to apply the changes. The lines now have arrows to show the line direction.
    An image showing the lines with arrows.
Article ID: 000017815
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
