PROBLEM
Xcode 16 compatibility issue with ArcGIS Maps SDK for Swift 200.5.0
Last Published: September 20, 2024
UPDATE: On September 18th, 2024 the ArcGIS Maps SDK for Swift 200.5.1 patch was released and is now availible.
Esri has identified a compatibility issue in Xcode 16.0 which causes builds to fail when using ArcGIS Maps SDK for Swift 200.5.0.  This means that you cannot use ArcGIS Maps SDK for Swift 200.5.0 to build projects for iOS 18 or macOS 15.  Esri has delivered ArcGIS Maps SDK for Swift 200.5.1 which addresses the issue.
Solution or Workaround
Developers using ArcGIS Maps SDK for Swift 200.5.0 should update to ArcGIS Maps SDK for Swift 200.5.1 using either Swift Package Manager or the Esri Developer download portal.
Please note that the 200.5.1 patch may introduce build warnings or errors to your project if Swift 6 language mode or Complete strict concurrency checking are enabled. The 200.5.1 release notes provide more details, including how to resolve these warnings and errors.
Additional details:
  • This explicitly only affects Xcode 16 with ArcGIS Maps SDK for Swift 200.5.0.
  • Earlier versions of ArcGIS Maps SDK for Swift are not impacted.
  • Earlier versions of Xcode are not impacted.
Article ID: 000033636
Software:
  • ArcGIS Maps SDK for Swift
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
