ERROR
Visual Fortran Run-Time error
Error Message
Attempting to start or use any of the ArcGIS Desktop products returns a Visual Fortran Run-Time error.
Cause
This error may occur when the system locale and the user locale in the Regional Options are not set correctly. ArcGIS loads the appropriate code page files, which are used internally by ArcGIS to support various languages and character sets, to perform language-related operations using both the system locale and the user locale settings.
Solution or Workaround
In order for ArcGIS to run properly under a selected language environment, the same language setting must be selected for the system default locale and the user locale. This procedure must be completed from the administrator account.
<a href='https://support.esri.com/en/knowledgebase/techarticles/detail/27176' target='_blank'>How To: Configure Windows to run ArcGIS in a selected language environment</a>
Article ID: 000005098
Software:
  • ArcMap 8 x
  • ArcReader 8 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
