DEPRECATION
Vector Basemap Deprecation Notice Affecting ArcGIS Runtime SDKs 100.5 and Earlier
Last Published: April 26, 2024
Beginning September 1, 2022, vector basemaps will no longer work correctly in applications using ArcGIS Runtime SDKs 100.5 and earlier. The application itself will continue to work, but the basemaps will not display correctly. You will see gaps, some of them large, in the basemap.
Recommendation
Developers are strongly encouraged to move their applications to a newer version of the ArcGIS Runtime SDKs before September 1, 2022. If that is not possible, an alternative is to use raster basemaps, which will require some code changes. Note that most raster basemaps are in mature support and are no longer updated.
Article ID: 000027565
Software:
  • ArcGIS Runtime SDK for NET
  • ArcGIS Runtime SDK for Android
  • ArcGIS Runtime SDK for iOS
  • ArcGIS Runtime SDK for Java
  • ArcGIS Runtime SDK for Qt
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
