PROBLEM
Unable to register ArcGIS GeoEvent Processor for Server when using a self-signed certificate
First Published: May 5, 2016
Unable to register ArcGIS GeoEvent Processor for Server when using a self-signed certificate over a Secure Sockets Layer (SSL) connection.
This article pertains to ArcGIS versions 10.1 and 10.2. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Cause
The registration fails when a self-signed certificate makes an untrusted connection to the browser while establishing the SSL connection.
Solution or Workaround
Add the self-signed certificate to the certificate authority (CA) to ensure a trusted connection to the browser.
  1. Stop ArcGIS GeoEvent Processor for Server service from the Services console. To do this, click Start, and in the search box, type services.msc to launch the console.
  2. Save a copy of the CA certificate to the folder: C:\Program Files\ArcGIS\Server\GeoEventProcessor\jre\lib\security
    This certificate only works with .cer files.
  3. To open a Command Prompt window as an Administrator, click Start > All Programs > Accessories, right-click Command Prompt, and select Run as Administrator.
  4. Navigate to the above folder location, "C:\Program Files\ArcGIS\Server\GeoEventProcessor\jre\lib\security".
  5. Within the folder, paste the following command to import the self-signed certificate to the CA (cacerts) file:
"C:\Program Files\ArcGIS\Server\GeoEventProcessor\jre\bin\keytool" -import -trustcacerts -file esrica.cer -alias esri_ca -keystore cacerts
In this example, the certificate is named esrica.cer. Users must replace this name with a unique name for the self-signed certificate. When prompted for a password, type changeit. For the Alias parameter, select any name; the alias is a unique name that easily identifies the certificate.
  1. When prompted to trust the certificate, click Yes.
  2. To implement the changes, restart ArcGIS GeoEvent Processor for Server from the Services console.
Article ID: 000011987
Software:
  • ArcGIS Data Store
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
