ERROR
Too many WebGL contexts. Unable to add the layer
First Published: September 30, 2020
Last Published: April 5, 2023
Error Message
After adding sixteen maps to an ArcGIS Insights page using a vector tile basemap, when attempting to add a seventeenth map, the map does not load, and it may be necessary to delete the files from your AppData folder if Insights stops working. The JavaScript API throws the error:
Cause
The 3.x version of the JSĀ API creates one WebGL context per vector tile layer added to a workbook, and Chromium has a limit of sixteen WebGL contexts. Mobile browsers have a limit of eight WebGL contexts.
Solution or Workaround
Use a raster basemap, rather than a vector tile basemap.
Additionally, the 4.x version of the JS API utilizes WebGL contexts differently so that this limit will not be reached as quickly. Consider creating a map in the new Map Viewer, or create an Instant app or web experience instead of using Web AppBuilder.
Article ID: 000024301
Software:
  • ArcGIS Insights
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
