ERROR
The changes you requested to the table were not successful
First Published: May 5, 2016
Error Message
New features cannot be added to a personal geodatabase. The following error is returned:
"The <edit> task could not be completed. The changes you requested to the table were not successful because they would create duplicate values in the index, primary key, or relationship."
Cause
The personal geodatabase was created (for example, as a result of checking out some data from another geodatabase) under a Windows operating system that has an older version of the msjet40.dll file (windows\systems32). The auto-number generator, used to allocate new ObjectIDS to the new features, has been corrupted. Attempts to add new features will result in this error. This is a known problem with msjet40.dll version 4.00.2927.4 or earlier.
Solution or Workaround
Upgrade the msjet40.dll file to the latest version.
To update Jet to the newest version, see the link below.
Article ID: 000005764
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
