ERROR
Run-time error '445' - Object doesn't support this action
Error Message
When using the IRelationalOperator::Equals method on a geometry bag, ArcMap returns the message, "Run-time error '445' - Object doesn't support this action".
Cause
This is a known issue. This method is not implemented yet.
Solution or Workaround
The code below demonstrates how to work around this issue programmatically. This code is an example only. It is not complete and will cause an error if you try to run it.
Code:
'If you have a geometry bag
Dim pGeometryBag As IGeometryCollection
Set pGeometryBag = New GeometryBag
'And you add some geometries to this bag
pGeometryBag.AddGeometry pPt
pGeometryBag.AddGeometry pPolygon
'The work around can be:
*Create IEnumGeometry Interface
Dim pGeomEnum As IEnumGeometry
*Set that inteface to the geometry bag
Set pGeomEnum = pGeometryBag
*Create a geometry interface
Dim pGeom As IGeometry
Dim count As Integer
*Create the relational operator
Dim pRelOperator As IRelationalOperator
*Loop in your geometry enumeration and
*extract each geometry and compare with
*another geometry
For count = 1 To pGeomEnum.count
Set pGeom = pGeomEnum.Next
Set pRelOperator = pGeom
MsgBox CStr(pRelOperator.Equals(pPt(0), vbOKOnly)
Article ID: 000004459
Software:
  • ArcMap 8 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
