PROBLEM
WMS attribute popups fail to render in Map Viewer if the header X-Frame-Options: SAMEORIGIN is returned by the hosting server
First Published: May 13, 2022
Last Published: August 17, 2022
Map Viewer and Map Viewer Classic do not render feature attributes in a popup for certain OGC WMS services. The popup displays, but no attribute information is contained, as shown in the next image.
The equivalent popups display correctly in ArcGIS Pro.
Cause
Map Viewer displays popup attributes in an iframe within the popup for security reasons. If the WMS is configured to return the header.
To the GetFeatureInfo request generated by ArcGIS Online for the popup, the response (attributes) is blocked from displaying in an iframe unless the request is coming from the same origin as the server.
Solution or Workaround
The solution is to have this response header removed at the hosting server end, or to display the attribute popups in ArcGIS Pro instead.
Article ID: 000027521
Software:
  • ArcGIS Online
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
