PROBLEM
Unable to update and publish surveys from ArcGIS Survey123 Connect
First Published: January 14, 2021
Last Published: April 27, 2022
When using ArcGIS Survey123 Connect to publish a survey, a folder of the survey is created in ArcGIS Online containing the feature layer, as well as a form item and a web map. This allows for flexibility in migrating the ArcGIS Online content. In some instances, when updating and republishing the survey using Survey123 Connect, the publishing process loads but does not complete, as shown in the image below:
The publishing page of a survey in ArcGIS Survey123 Connect that loads and does not complete.
Cause
This issue occurs when the form item of the survey has been moved to another folder in ArcGIS Online. This results in the item ID of the ArcGIS Online folder where the form item is to not match with the ID in the local ITEMINFO file of the survey.
When the survey is originally published, the ID of the ArcGIS Online folder where the form item is stored is saved locally in an ITEMINFO file. Every time the survey is subsequently published, the ID in the ITEMINFO file must match with the ID of the ArcGIS Online folder that stores the form item.
The Form item in the ArcGIS Online folder that contains the ID that must match with the ID in the ITEMINFO file saved locally
Solution or Workaround
To resolve the issue, follow the steps below to edit the the survey's ITEMINFO file to ensure the item ID matches the ArcGIS Online folder ID where the form item is stored.
  1. In ArcGIS Online, navigate to Content > My Content.
  2. Navigate to the folder that stores the form item, and copy the folder's item ID from the address bar of the web browser, as shown in the image below.
The page of the survey folder displaying the item ID of the folder in the address bar.
  1. On the local machine, navigate to the survey folder, and open the survey's ITEMINFO file with a text editor.
The ITEMINFO file of the survey by navigating in the local machine's File Explorer directory.
  1. Search for the "ownerFolder" parameter, and ensure the values match with the item ID in Step 2. If the item ID is different, update the parameter values with the item ID copied in the Step 2, and click Save.
Modifying the ownerFolder parameter to ensure it has the same item ID as the survey folder's item ID in ArcGIS Online.
  1. Republish the survey from Survey123 Connect.
Article ID: 000025001
Software:
  • ArcGIS Online
  • ArcGIS Survey123 Connect
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
