PROBLEM
Unable to save new attribute rules using the ArcGIS Data Reviewer checks in ArcGIS Pro
First Published: November 11, 2022
Last Published: November 11, 2022
The ArcGIS Data Reviewer checks are tools that allow users to evaluate data based on specific conditions. Sometimes, when creating new attribute rules using one of the Data Reviewer checks, the rules cannot be saved in ArcGIS Pro, as displayed in the following image. The Duplicate Vertex check is used as an example in this article.
The image of the Duplicate Vertex rule cannot be saved in ArcGIS Pro.
Cause
The issue occurs when the ‘Global IDs’ check box for the feature classes is not checked.
Solution or Workaround
This workflow requires the ArcGIS Data Reviewer license.
  1. In ArcGIS Pro, right-click the polyline or polygon feature class in the Catalog pane. Click Manage.
The image of the context menu of a feature class with the Manage option being selected.
  1. In the Feature Class Properties window, check the Global IDs check box. Click OK.
The image of the Feature Class Properties window with the Global IDs check box being checked.
The image below shows the new Duplicate Vertex rule is saved in ArcGIS Pro.
The image of the new Duplicate Vertex rule is saved in ArcGIS Pro.
Article ID: 000028679
Software:
  • ArcGIS Pro
  • ArcGIS Data Reviewer
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
