PROBLEM
Unable to resize the legend in ArcGIS Pro
First Published: April 27, 2022
Last Published: April 27, 2022
Legends are layout elements that explain the meaning of the symbols used to represent the features of a map. There are instances where the legend cannot be resized from the layout view or editing the Size setting is disabled, as shown in the image below.
The Format Legend pane with the Placement tab for editing legend size disabled.
Cause
The ‘Adjust frame’ fitting strategy only permits movement of the legend but not resizing.
Solution or Workaround
Depending on the suitability, use one of the following options to resize the legend in ArcGIS Pro.
Change the Fitting Strategy setting of the legend
  1. Open the ArcGIS Pro project.
  2. In the Contents pane, double-click Legend to open the Element pane.
  3. In the Element pane, click the Legend Arrangement Options tab.
  4. Under Fitting Strategy, click the drop-down arrow and select an option.
The Format Legend pane with the option for fitting strategies.
The image below demonstrates editing enabled after amending the fitting strategy, and resizing the legend is now possible.
The Format Legend pane with the Placement tab enabled.
Convert the legend to graphics
Legends converted to graphics lose connection to the map. Edits to the layers are not updated in the legend graphics, therefore, they must be done manually in the legend.
  2. In the Contents pane, right-click Legend and click Convert to Graphics.
The Contents pane with the Convert from legend to graphic option.
  1. In the Contents pane, right-click Legend and click Ungroup.
The Contents pane with the Ungroup option.
  1. In the Contents pane, under Drawing Order, click the desired legend items to open the Element pane.
  2. In the Element pane, click the Placement tab. Under Size, change the Width and Height of the legend item to the preferred size.
The image below demonstrates the resized legend, Agriculture in Canada, 1971, converted to graphics.
The Agriculture in Canada, 1971 legend with legend items in graphics.
Article ID: 000027534
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
