PROBLEM
Unable to display feature layers in a group layer in Web AppBuilder for ArcGIS
First Published: July 29, 2019
Last Published: June 26, 2020
When opening a web map in Web AppBuilder for ArcGIS, the feature layers in a group layer in the Layer List widget are not visible on the map.
The following image shows a group layer. Although the 'Sierra Nevada Snow and Ice Climbs - Routes' layer is listed in the Layer List widget, the layer is not displayed on the web map.
Image showing the Sierra Nevada Snow and Ice Climbs - Routes feature layer not displayed on the web map
Cause
The following are the possible causes:
  • The feature layers are not hosted in ArcGIS Online.
  • The hosted feature layers are not shared with the required group.
Solution or Workaround
Depending on the cause, use one of the options below to resolve the issue.
  1. Manually save and publish each feature layer in ArcGIS Online as a hosted feature layer. Refer to ArcGIS Online: Publish hosted feature layers for more information.
  2. When configuring the Layer List widget in Web AppBuilder for ArcGIS, select the hosted feature layers to display. Refer to Web AppBuilder for ArcGIS: Layer List widget for more information.
Alternatively, use the Bookmark widget to display the group of layers one at a time.
For members of a group to access the hosted feature layers, share the layers with the group. Refer to ArcGIS Online: Share layers and views for more information.
The following image shows the 'Sierra Nevada Snow and Ice Climbs - Routes' layer in a group layer displayed in the Web AppBuilder for ArcGIS map.
Image showing the Sierra Nevada Snow and Ice Climbs - Routes hosted feature layer displayed on the web map
Article ID: 000021251
Software:
  • ArcGIS Web AppBuilder
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
