PROBLEM
Unable to append data to an ArcGIS Online hosted feature layer in ArcGIS Pro
Last Published: September 29, 2022
Data from an ArcGIS Pro feature class can be appended to an ArcGIS Online hosted feature layer using the ArcGIS Pro Append tool. In some instances, attempting to append data to a hosted feature layer fails, and returns the warning message, 'WARNING 000594: Input feature <FeatureID>: Function not implemented.'
Image of the warning message.
Cause
This is a known limitation. Refer to BUG-000133544 for more information.
Solution or Workaround
Follow the steps below to resolve the issue.
  1. In ArcGIS Pro, create a new project, and add a new map. Refer to ArcGIS Pro: Create a project for more information.
  2. Add the feature class and hosted feature layer to the project. Refer to ArcGIS Pro: Use a portal connection for instructions to add the feature layer.
  3. Append the data from the feature class to the hosted feature layer using the Append tool.
    1. On the Parameters tab, select the layers for Input Dataset and Target Dataset.
    2. On the Environments tab, uncheck the Preserve Global IDs check box.
    3. Click Run.
The Environments tab.
The data from the feature class is successfully appended to the hosted feature layer without warning messages returned.
Article ID: 000024458
Software:
  • ArcGIS Online
  • ArcGIS Pro 3 0
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
